1992 Toyota Camry power window switch assembly
1992 TOYOTA CAMRY
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHNNYBOYBOY
I am supposing that i need to remove all the trim from the door in order to get to the actual contacts of the drivers side control of the power switch assembly--hopefully,you will tell me that i can just lift the assemble out from the panel? i am 99% sure that only the contact for the driver side window is bad as i have been having problems but was able to work it prior--now i can feel the difference between that switch and the other swithes when pressed --i very seldom use the passenger side windows (a/c is always on because of our summer weather all year long) thanks for your help...Aloha!
Feb 3, 2009 at 6:04 PM
Take the door panel off its just a clip on compress it to remove switch
Feb 3, 2009 at 7:22 PM
