1992 Toyota Camry noise
1992 TOYOTA CAMRY
108,355 MILES • 6 CYL • 4WD • AUTOMATIC
KYAKAY
Hallo,
sometimes car makes a high pitched sound when I start after running the a/c. sometimes will also make the same noise without running the a/c.
what is the cause?
also how do i change the light bulb on front headlight?
Jul 19, 2008 at 12:01 AM
MHPAUTOS
  • 31,937 POSTS
Hi there, i would be checking the condition & adjustment off all the drive belts. As for the light, take off the plastic cover over the globe holder if fitted, unplug the globe and the globe is held in with a wire clip.
Mark (mhpautos)
Jul 19, 2008 at 12:18 AM
