1992 Toyota Camry leaking fluid
1992 TOYOTA CAMRY
165,000 MILES • 4 CYL • FWD • AUTOMATIC
LMAGUIRE
Power steering fluid reservoir empty and again after refill. Car seems to have left a trail of the fluid down my driveway. It looks like power steering pump is located way back near firewall but I can't even see it. Is it likely that it needs a new pump and how difficult is it to remove and replace it?
Dec 20, 2009 at 7:59 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, you should have this up on a hoist to check the high & low pressure hoses and the rack as any one of these could be leaking, have it all washed down first then it will be easier to see the fresh leak.
mark (mhpautos)
Dec 20, 2009 at 11:51 PM
