1992 Toyota Camry Late final overdrive shift in cold weathe
1992 TOYOTA CAMRY
127,500 MILES • 4 CYL • FWD • AUTOMATIC
STREET RAT
  • 5 POSTS
Transmission will not shift into final overdrive shift until engine is thoroughly warmed up. Temperature below 40 degrees F triggers problem. After shifting into final overdrive shift, it will shift back out when engine temperature has decreased during highway driving then shift back into overdrive after about 5 minutes. Transmision flushed in summer of 2008. No engine trouble lights or transmission overdrive trouble lights.
Jan 8, 2010 at 8:49 AM
MMPRINCE4000
  • 8,548 POSTS
This may be as simple as a bad thermostat.
Final overdrive or torque convertor lockup is dependant on speed, load, and engine temp.
If engine temp is slow to get to operating temp. trans will not shift into final OD.
I would change thermostat, and use ONLY a Toyota replacement part.
Jan 9, 2010 at 7:52 AM
STREET RAT
  • 5 POSTS
Found out it was a bad thermostat.
May 13, 2010 at 8:10 AM
MMPRINCE4000
  • 8,548 POSTS
Glad to hear it. Thanks for using 2carpros.
May 13, 2010 at 10:17 AM
