1992 Toyota Camry BRAKES
1992 TOYOTA CAMRY
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
TIMPATTERSON
MY PEDAL HAS RESISTANCE WHEN VEHICLE IS OFF. WHEN TURNED ON IT SINKS TO THE FLOOR. THERE IS PLENTY OF FLUID IN RESEVOIR. I HAVE BLED THE BRAKES THREE TIMES AND SOME AIR DID COME OUT BUT THE PROBLEM STILL EXISTS. IS IT THE MASTER CYLINDER OR THE BRAKE BOOSTER? HOW CAN I TELL BY LOOKING IF IT HAS ATILOCK BRAKES?
Jan 26, 2010 at 5:01 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if it has ABS then not only should their be an "ABS" stamped on the brake pedal rubber but also their should be a dummy light in the dash that will light up when key is first turned in ignition that says "ABS" . fault probably lies with the master cylinder, when booster fails it will feel extremely hard to push brake pedal and almost as if you can't stop the car .
Jan 26, 2010 at 5:19 PM
