1992 Toyota Camry brake lights wont work
1992 TOYOTA CAMRY
THEBIGESTPYRO1234567
Brakes problem
1992 Toyota Camry 4 cyl Front Wheel Drive Manual
the brake lights wont come on we replaced the brake switch and the failure brake module in the rear panel but the brake lights wont work turn signals and the running lights work and i replaced the module cause it looked burnt up and the new one looked burned up in the same spot
Jan 22, 2009 at 9:59 PM
failure brake module are you refering this as the light failure sensor?
Jan 22, 2009 at 10:27 PM
yes i thats what its called its in the trunk behind the lining
Jan 22, 2009 at 10:58 PM
At the sensor have someone step on the brake and check for power on the green and white wire terminal-do you have it
Jan 23, 2009 at 12:19 AM
