I have a 1992 camry w 120000 odo miles. To solve starting and engine stalling problem, the fuel regulator, damper, water temperature sensor, fuel filter, fuel pump was replaced. Problem remains the same. So I replaced the TPS to no avail. Luckily I was able to return it w refund. I suspected the MAP sensor and by tinkering w it i discovered that it will start and continually run ok with the vacuum hose not attached to the MAP sensor and engine dies when i connect it. I try to drive it around the block and after 30 minutes with d engine hot, the engine dies and WILL NOT START. After about 8 hours with engine cold IT START again (All this time while the MAP sensor vac hose is unplug). I tried another MAP sensor from another good running 92 camry and the problem is the same. Kindly help how to approach this problems sans taking the car towed to a toyota shop and setting my small banks account pummelled.
Sep 24, 2010 at 5:40 PM
