1992 Toyota Camry
1992 TOYOTA CAMRY
178,000 MILES • 4 CYL • 2WD • AUTOMATIC
95ECLIPSE
Hi when i started dricing my 92 camry the other day as i began to brake the car started to make a noise and shake.
Aug 29, 2010 at 10:43 AM
DSPLC
  • 220 POSTS
If the noise is coming from the front brakes, it means the brake pads are worn out. And the shake means your brake rotors needs to be turn by a machine shop. Brake rotors after prolonged use, they can become warped, glazed, or damaged and can be restored by processing (or turning) them. A warped rotor will give the feeling of shuddering when the brake is applied, and can be so bad that the steering wheel can sometimes shake.
Processing brake rotors involves removing the rotor from your car and then having a machine shop, automotive repair center, or even an automotive parts store spin them on a lathe and slowly grind down the surfaces until they are clean, level, and proper.
If you can afford a new rotor for both sides, just replace it. So, you need new brake pads and rotors.
Mar 11, 2021 at 12:42 PM
