1992 Toyota Camry
1992 TOYOTA CAMRY
292,000 MILES • 4 CYL • FWD • AUTOMATIC
GSR123
  • 4 POSTS
loss of power ... changed coil pack, replaced spark plugs and wires, replaced rotor and cap, checked timing belt and retimed to 10 degs BTDC. Son was driving home and went over railroad tracks and it stalled. found coil pack bad and replaced... idles ok but no driving power
May 19, 2010 at 9:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check fuel pressure, fuel filter may need replaced.
May 19, 2010 at 10:02 PM
GSR123
  • 4 POSTS
did that as well and put fuel injector cleaner... its seems to be only at accelleration, once it get to speed it is ok
May 21, 2010 at 10:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check engine light on? several sensors could cause this issue including MAF sensor and crankshaft sensor.
May 21, 2010 at 2:34 PM
GSR123
  • 4 POSTS
check engine light is not on ... thinking maybe throttle position sensor ... maybe bad gas? ... crankshaft and camshaft sensors appear to be ok
May 21, 2010 at 5:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
possibly clogged up catalytic converter or exhaust blockage. any type of sensor failure will almost always set off the check engine light. watered down or contaminated fuel would most likely cause engine to idle rough along with lack of power.
May 21, 2010 at 5:11 PM
GSR123
  • 4 POSTS
true ... was thinking i would disconnect exhaust at manifold for a short drive to see if catalytic converter or exhaust blockage is the problem but will wait a couple of days to see if clogged injectors work themselves clean
May 21, 2010 at 5:25 PM
