1992 camry Air Conditioner only working on passenger side
1992 TOYOTA CAMRY
MSANDERSON
1992 Camry 4 cyl. Automatic w/ 226000 miles. I had the system recharged, but it seems that the cold air only comes out of the passenger side vents. Hot air is coming from the driver side vents. Does the evaporator have two ports, where one may be clogged when dispensing.... your help is appreciated...
Jul 17, 2007 at 7:39 PM
[quote:65d60cca53="msanderson"]1992 Camry 4 cyl. Automatic w/ 226000 miles. I had the system recharged, but it seems that the cold air only comes out of the passenger side vents. Hot air is coming from the driver side vents. Does the evaporator have two ports, where one may be clogged when dispensing.... your help is appreciated...[/quote:65d60cca53]
Could be the driver's mode door is binding
Jul 18, 2007 at 4:48 PM
