1991 Toyota Camry water pump leak
1991 TOYOTA CAMRY
G13
Engine Cooling problem
1991 Toyota Camry 4 cyl Two Wheel Drive Automatic
my water pump is leaking from a hole right in the front...it looks to have threads, like a bolt or seal...i'm wondering if this is an 'easy' fix...like sealant or a bolt? and if not will i need to lift the engine and remove the timing belt to replace the water pump?
ADDITIONAL INFO PLEASE....
is this a driveway job...or will i need a shop?
Aug 17, 2009 at 9:41 PM
BMRFIXIT
  • 19,053 POSTS
Pump no good need to be replace
also I would replace the timing belt too
Aug 17, 2009 at 9:57 PM
