1991 Toyota Camry choosing the right booster
1991 TOYOTA CAMRY
248,000 MILES • 6 CYL • 2WD • AUTOMATIC
ITMERO
what would be the right booster pack to buy for a 35N type battery with 800CCA? I know you would highly recommend me just to have my car repaired but just for the sake of knowing and answering my question.
what is the difference between these:
1) a booster pack with 700 crank assist amp (usually seen at canadian tire, motomaster eliminator brand)
2) a 100/200Amp engine starter (sample. schumacher 2/10/40A, 6/12V charger and 100/200Amp engine starter with battery tester)
will I end up better buying item 1 with 700 crank assist amps or item 2 with 200 amps engine starter?
as for additional information. my main fuse rating is only 150 amps (I can see it connected to the positive terminal of the battery) and I have 35N type battery
Aug 6, 2010 at 7:00 PM
MHPAUTOS
  • 31,937 POSTS
I feel option 2 will be best suited.
mark (mhpautos)
Aug 7, 2010 at 7:56 AM
ITMERO
thank you very much for your prompt response. In addition to my first question, I live here in winnipeg, manitoba, canada where winter temperature could dip as low as -40degrees centigrade (celsius) in 7 days. my car would be parking on an outdoor parking exposed to the cold temperature as I go to school for my class. will item 2 be good in this condition? ( i would be leaving the booster inside the car on an outdoor parking lot for about 10 hours). thank you very much again.
Aug 7, 2010 at 1:07 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Well we are worlds apart, i liver in Australia and often have to deal with +40 Deg C i really don't have any experience with such cold, i really don't know who to ask about that. maybe talk to a battery retailer they may have a better idea as to what to expect under your local conditions.
mark (mhpautos)
Aug 7, 2010 at 6:24 PM
