1991 Toyota Camry charging
1991 TOYOTA CAMRY
178,000 MILES • 4 CYL • FWD • AUTOMATIC
HURLEY-155
i replaced my alternater and my battery and it still wont charge the battery
Mar 9, 2008 at 4:35 PM
Did you use a voltmeter to confirm it-If so there's a D-hole behind the alternator-stick an object in there and ground the tap-if voltage increases the internal voltage regulator is defective. If not the alternator
I know its new stuffs but there's such thing as manufacture defects-
Double check all connections from and to the alternator. also at the battery-check all fuses
Mar 9, 2008 at 4:45 PM
HURLEY-155
no i didnt i took the alternater down to the parts house and they tested it and told me it was fine and were are all of the regulaters at?
Mar 9, 2008 at 6:42 PM
