1990 Toyota Camry Timing
1990 TOYOTA CAMRY
250,000 MILES • 4 CYL • 2WD • AUTOMATIC
SAETTONE
I have no power after setting the timming. I followed the instructions on the lable under the hood. When I insert the jumper into the connector like the lable says, the RPM's go way down and the timing was set at 10 BTC. I set it to 0 BTC, pulled out the jumper, the RPM's went back up but the timing said @10~15 BTC and there is no power when driving.
Jun 18, 2010 at 2:30 PM
With the jumper on it should be 10deg BTDc and advances when unjumpered
Jun 18, 2010 at 3:57 PM
SAETTONE
I set it back to 10 and its ok now. Why would the label say to set it at 0 with the jumper in? I also read in the manual, when the jumper is inserted that the RPM's should rise then return to normal, not decrease as it did in my case.
Jun 19, 2010 at 8:54 PM
