1990 Toyota Camry Idle speed
1990 TOYOTA CAMRY
25,500 MILES • 6 CYL • 2WD • AUTOMATIC
ABBOTTIM
Hey guys. Idle speed will sometimes be normal (6-700), but is often in the 1200 area after some driving. But when running the air conditioner and even shutting that off, it can go settle in even higher - 1800-2500rpm!!
I have sprayed carb spray into the Idle Control Valve air intake while connecting/disconnecting the electrical to it. I can't access the valve from the air chamber; although I did spray that area down. Any other thoughts on correcting this?
Apr 20, 2010 at 9:52 AM
KHLOW2008
  • 41,814 POSTS
Hi abbottim,
Thank you for the donation.
Check the coolant level. Shortage of coolant would cause the idle to increase.
Check the thermostat. A stuck in open thermostat would result in the coolant operating below operating temperature, especially with AC turned ON.
Apr 20, 2010 at 12:35 PM
