Hey guys. Idle speed will sometimes be normal (6-700), but is often in the 1200 area after some driving. But when running the air conditioner and even shutting that off, it can go settle in even higher - 1800-2500rpm!!
I have sprayed carb spray into the Idle Control Valve air intake while connecting/disconnecting the electrical to it. I can't access the valve from the air chamber; although I did spray that area down. Any other thoughts on correcting this?
Apr 20, 2010 at 9:52 AM
