1990 Toyota Camry Can't go any faster than idle
1990 TOYOTA CAMRY
WVXCJERK
Shakes or Wobbles problem
1990 Toyota Camry 6 cyl All Wheel Drive Automatic
The other day, I was accelerating from a strandstill. The second the car started moving, I could notice it was running a little rough. I ignored it (I know, I'm a genius) and once I made it up to about 50, it started shaking. I pulled into a side street, and when I went to step on the gas, all it did was rev the engine, like it was in neutral. I got to a stop, turned the car off, waited a few seconds, and then turned the car back on. No problems. I slid the car into neutral and revved; no problems. But when I slid it into drive, it lurched (while my foot was on the brake), but stayed on. When I released the brake, it was idling well, but when i depressed the gas at all, It did the same lurches. I didn't want to go any faster than that, fearing something would explode. It was eventually towed back to my house. I've been too afraid to even try it again. Any ideas?
May 14, 2010 at 4:13 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would start with a scan, check for any unresolved fault codes, also have the fuel pressure checked as well.
mark (mhpautos)
May 15, 2010 at 9:17 AM
