1990 Toyota Camry Broken Tie rod inner
1990 TOYOTA CAMRY
BCTREEFROGS
Tires and Wheels problem
1990 Toyota Camry 6 cyl Two Wheel Drive Automatic
I have a broken tie rod, I'm about 90% sure its the inner one, all I need to know is how hard it is to fix and what kind of tools I will need. Thanks in advance.
Oct 15, 2009 at 6:00 PM
JOE C.
  • 25 POSTS
what makes you think its the inner tie rod?
what are the symptons?
i could be wrong, consult a Haynes manual, but on this model i think its easiest to pull out the rack, then replace the inner. if you decide to do it while the rack is still installed, then you will need a special tool. do an internet search to find an inner tie rod removal tool with the correct size adaptor.
Oct 23, 2009 at 5:58 AM
