1989 Toyota Camry Oxygen sensor location
1989 TOYOTA CAMRY
115,000 MILES • 4 CYL • 2WD • AUTOMATIC
DCHUC
I just want know the location of the front oxygen sensor for my 1989 camry?
Sep 19, 2010 at 1:35 PM
SATURNTECH9
  • 30,869 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_1989_toyota_camary_4cyl_o2_sensor_1.jpg
OXYGEN SENSOR REMOVAL AND REPLACEMENT: 1. Allow the exhaust system and the Oxygen Sensor to cool down before attempting removal. 2. Disconnect the sensor wire connector. 3. Unbolt the sensor, taking care NOT to break the mounting studs. NOTE: DO NOT use penetrating lubricant to loosen rusted mounting nuts unless absolutely necessary. The silicone in the lubricant will contaminate the new sensor, if it comes in contact with the sensor tip. 4. Remove the Oxygen Sensor and gasket from the mounting flange. 5. Always install the Oxygen Sensor using a new base gasket. 6. Torque the mounting nuts evenly to 14 ft.lbs. (20 N-m). 7. Reconnect the wire connector. It's in the exhaust manifold.
Sep 19, 2010 at 2:57 PM
