1989 Toyota Camry leaks
1989 TOYOTA CAMRY
FARGEEK
Smells problem
1989 Toyota Camry 6 cyl Front Wheel Drive Automatic
hey every time I start up the engine on the camry I begin to smell oil or some kind of fuel leaking out and down to the ground and when I open the hood I see smoke coming somewhere araound the exaust manifold or so
but I am not sure where it is exactly leaking from but its not the tank or filler so
Can you tell me what exactly do I have to do in order to fix this problem please???
and the back lights do not work
Jul 17, 2010 at 10:51 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
With any fluid leak from the engine you will have to first give the engine a good wash down top & bottom, and drive the car check with a light and mirror for any signs of fresh oil leaking from the engine and transmission, you may have to get the car onto a hoist to view the under side properly, now which rear lights don't work, parkers, brake or indicators or reverse, in any cased first check fuses and globes.
mark (mhpautos)
Jul 18, 2010 at 12:32 AM
