1989 Toyota Camry Battery Drains
1989 TOYOTA CAMRY
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
JPSENTERPRISES05
  • 6 POSTS
The vehicle was running fine. 1 Day it wouldn't start. Got the Alternator tested and put a new battery in the vehicle. Vehicle will still drain if left overnight. Any ideas how to trace this problem or what it could be?
Thank you,
Josh
Nov 25, 2008 at 2:05 PM
This first test is simple but you would be surprised at how many people simply leave there headlights on over night. If the battery is dead check the headlight control switch. If the switch is in the on position turn the switch off and jump start or charge the battery. The battery should re-gain it's state of charge after about 15 minuets of driving and your problem will solved. If headlight switch is off proceed to next step
Inspect the interior illumination lights (dome light) when all the doors are shut the interior lights should go off. If the lights stay on check the headlight interior light bypass switch located at the headlight switch. This switch is designed to illuminate the interior lights indefinitely when the doors are closed and is used when people are left inside the car and need light for a particular reason. To check the headlight interior light bypass switch turn the headlight control knob fully right then left, you should feel a small bump in the operation letting you know when the switch is activated. Deactivate the switch and re-test dome light operation. Some cars have a delay sentinel that will leave the interior light illuminated for a preset amount of time and is used for safety reasons. If this delay mechanism fails it can leave the interior light on draining the battery. If this is the case the interior light delay sentinel will need to be replaced. If all tests ok proceed to next step
Inspect the car stereo tape deck or CD player, sometimes a tape or CD will get stuck in the player either loading or ejecting causing the motor inside the tape deck to stop. This small motor can draw enough electrical power to drain the battery over night. If a tape or CD is stuck in the player try using a small flat bladed screw driver or small tweezers to remove the culprit. If the stuck tape or CD will not come out remove the player and disconnect the unit. Once the unit has been removed either replace the player or send it to a stereo repair shop and reinstall when repaired. If player tests ok proceed to next step
Inspect the glove box illumination light, in most cases this light is controlled by a small pin switch. If this switch malfunctions or is mal-adjusted it will allow the glove box light to stay on draining the battery down over night. To check for this condition look for the light inside the glove box through the small cracks in the glove box door. If this light is illuminated when the glove box door is shut replace or readjust the switch to operate properly and recheck light operation. If it tests ok proceed to next step
Inspect the trunk illumination light, in most cases this light is controlled by a small pin or a mercury level switch. To test the trunk light operation observe the light as you close the trunk lid, the light should go off when the trunk lid is nearly shut. If the light doesn't go off replace or readjust the switch and recheck operation. If it tests ok proceed to next step
Inspect the hood (covers the engine) illumination light, in most cases this light is controlled by a small pin or a mercury level switch. To test the hood light operation observe the light as you close the hood, the light should go off when the hood is nearly shut. If the light doesn't go off replace or readjust the switch and recheck operation. If it tests ok proceed to next step
Inspect the cigarette lighter in both front and rear passenger compartments, remove the lighter unit and look down inside the light socket. You are looking for debris that can cause an electrical draw like a penny or a gum wrapper. Anything that can cause an electrical draw will drain the battery power. If debris is found remove it with a small pair of tweezers. (note: sometimes when inserting tweezers or removing debris from the cigarette lighter a fuse can blow, if so replace the fuse with new after the debris has been removed) If the test is proceed to next step
Inspect the electric seat control switch, this switch can become sticky or weak allowing the switch to stay engaged forcing the seat motor to draw power from the battery until dead. To check for this condition check the operation of the seat control switch if it does not return the neutral position or is sticking in one position replace the switch with new and recheck.
:please let me know what you find
Nov 25, 2008 at 5:02 PM
JPSENTERPRISES05
  • 6 POSTS
I'll be working on the vehicle after thanksgiving.
Vehicle doesnt have the following components:
Hood Light
Tape/CD Deck
Power Seats
I haven't checked the Glove Box, or the Trunk and will.
Assuming all of these items are working. Where else could a power source be drawn from? This vehicle is a 1989 so I can't imagine the "computers"/ecu would be working when the vehicle is off.
Thank you for the long and descriptive response,
Josh
Nov 26, 2008 at 12:58 AM
Hi, no the comp is off when the key is off, unless the main power relay is sticking,,, which it could be. please let me know what you find and we can go from there. have a good thanksgiving !
Nov 26, 2008 at 1:15 AM
JPSENTERPRISES05
  • 6 POSTS
I brought my vehicle to my mechanic and he found a broken wire in the tail light. He fixed that, but the car is still draining.
What else can I do? Where can i check? Can I check from the fuses I read about using a volt ohm meter?
Please help!!!
Thanks
Jan 12, 2009 at 12:25 AM
Remove the battery cable from the negative side of the battery. Install a test light between the terminals. It will illuminate if there is a systems draw. Then remove fuses until the draw stops. Troubleshoot the circuit and go from there. Please let me know what happens.
Jan 12, 2009 at 12:46 PM
JPSENTERPRISES05
  • 6 POSTS
Where can i locate a tester fuse light?
Thanks,
Josh
Jan 12, 2009 at 2:43 PM
JPSENTERPRISES05
  • 6 POSTS
I have a circuit tester. I was asking about the "tester" light in between the terminals?
Thanks,
Josh
Jan 12, 2009 at 3:15 PM
test light, tester light,,, same thing
Jan 12, 2009 at 4:07 PM
