my driver side transsaxle is broke ....i went to replace it but cannot seam to get the top strut bolt to line up and go in ...could you tell me the proper proceedure to remove and install the transaxle...i think ive should not have had to remove the bolt...
on the strut.. itook it apart again and put the bolt in ..but than i cannot get the cv joint in the hub...
and cannot get a spring compressor to work either...
i must be using a bad procedure..how is it normally done
Sep 13, 2010 at 10:29 AM
