1988 Toyota Camry White Smoke from back of the car
1988 TOYOTA CAMRY
220,000 MILES • 4 CYL • 2WD • AUTOMATIC
THR_MHMD
Hi
I have Toyota Camry 1988 model and after the recent service the car started immitting white smoke from the back. The smoke reduces after some time and after around half and hour becomes minimul or finshes. Can you please advise me what could be the cause?
thanks
Tahir
Feb 4, 2010 at 4:29 AM
White smoke emitting out of the tailpipe is an indication of coolant burning in the combustion chamber. Are you overheating? Is so get it block and pressure tested to rule out a blown headgasket cracked head or block, intake manifold. Check oil if its milky looking
Feb 4, 2010 at 5:06 AM
THR_MHMD
No the car is not overheating. The smoke colour is bluish not white. It is too much when I start the car but reduces after I drive for 1/2 an hour or so. Any help please?
[quote:e66a4c1abd="rasmataz"]White smoke emitting out of the tailpipe is an indication of coolant burning in the combustion chamber. Are you overheating? Is so get it block and pressure tested to rule out a blown headgasket cracked head or block, intake manifold. Check oil if its milky looking[/quote:e66a4c1abd]
Feb 10, 2010 at 10:53 PM
Bluish is a sign of oil burning-sounds like valve seals/stems/guides leaking
Feb 11, 2010 at 5:30 AM
THR_MHMD
Thank for the answer. So why would the smoke go off after 1/2 an hour or so?
[quote:8b88abe80a="rasmataz"]Bluish is a sign of oil burning-sounds like valve seals/stems/guides leaking[/quote:8b88abe80a]
Feb 11, 2010 at 4:31 PM
If it was the rings you'll see all the time whether its in park or moving-
Feb 11, 2010 at 4:44 PM
