1986 Toyota Camry Headlights
1986 TOYOTA CAMRY
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
KANDERSONS92
Dim headlights dont work but brights do, nothing wrong with the fuse already replaced it and didnt fix the problem. I dont know if theres a problem with the switch or electrical wiring. How can you tell which if possible at all and how do i fix the problem?
Oct 28, 2010 at 2:10 PM
KHLOW2008
  • 41,814 POSTS
Hi Kandersons92,
At the light switch, ground the Red/Green wire and if low beams comes on, the light switch is bad.
Oct 29, 2010 at 1:41 PM
