1980 Toyota Camry Hood will not open
1980 TOYOTA CAMRY
12,000 MILES • 4 CYL • 2WD • AUTOMATIC
HALFCHIHUAHUA
My hood willl not open. I heard a pop when I pulled the cable but the hood didn't open the gap needed to open it, as usual. Now, when I pull the latch I don't hear the pop.
Does anyone know anything I could try, or a ballpark figure on getting it repaired.
Thanks
May 25, 2010 at 11:03 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Do you still have tension on the release lever, do you feel that it may be broken? if not it may be out of adjustment , try having someone push down on the bonnet while you pull the lever, this sometimes releases the latch, if not get a mechanic to put it up on a hoist to trigger the lock from underneath the car, start here.
mark (mhpautos)
May 25, 2010 at 7:02 PM
