2002 Toyota Avensis Wrong Oil
2002 TOYOTA AVENSIS
106,000 MILES • V12 • 2WD • MANUAL
NECHAMER
My oil was low and accidently i inserted Helix Diesel oil. A few adys later i checked the oil level eith the dip stick and it showed the oil level just below the second dot. When i opened the cap to put in more oil i noticed the oil had hardened, which is when i relised that i did somthing wrong. Do I need to worry about this and if so what should i do? Is this urgent?
Many thanks for your help and advise.
Feb 11, 2010 at 5:59 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You do not want to run the diesel oil in the petrol engine, i would ad a flush and drain it out, you wont do any long term harm if you get it out sooner rather than later.
mark (mhpautos)
Feb 11, 2010 at 6:21 AM
NECHAMER
Thanks very much for that quick response.
Feb 11, 2010 at 6:31 AM
MHPAUTOS
  • 31,937 POSTS
Thank you for using Car pros, if you have any more queries post here.
mark (mhpautos)
Feb 11, 2010 at 6:44 AM
