1998 Toyota Avensis Wing mirror fitting Problems
1998 TOYOTA AVENSIS
130,000 MILES • 4 CYL • FWD • MANUAL
PCLARKE34
Hello I have a Toyota Avensis 1998 1.8
My wing mirror hit a bird the other day,
and smashed the wing mirror causing it also to come loose, i have replaced some new glass over the old broken glass but i can not get the mirror to fit in to housing.
the mirror is electric also heated, there are 3 pivots balls to try an push it onto one main center (,black) then two yellow/blue smaller pivot balls.
Any Help would be good ..
Many Thanks
Jun 29, 2010 at 10:37 AM
Hello, Even though you can buy the mirror glass separately can be difficult to install. Sometimes you can just give it a "pop" and the glass will set in, other times you must replace the mirror as a unit.
Jul 12, 2010 at 2:50 PM
