TOYOTA 03 CAMRY AND 00 AVALON
2003 TOYOTA AVALON
GOTORQUE
I just changed the oil n filter for my 2003 Camry LE, and a 2000 Avalon XLS, both have automatic transmission. I used 10w 30 oil, 4 quarts for both vehicles.
What are the chances that after changing the oil for both vehicles that I would have the same problem.
when gear is put into drive, cars does not engage immediately. Once engaged, cars will rev with slight forward progress.
I do know how to do a basic oil n filter change. Do to time constraint I have been sending both vehicles to my local garge for basic oil changes. I did notice that both oil plugs were replaced with hex head plugs. Foul play from my local garage? Any assistance would be greatly appreciated...
Feb 7, 2007 at 4:50 AM
UTS
  • 8 POSTS
Sounds like there may be no automatic transmission oil in the transmissionor or You didn' t accidently drain the transmission oil and put 10 w 30 in there?
I don't mean to offend, you probably know what you are doing, but this sounds a lot like a transmission problem.
Feb 7, 2007 at 5:23 AM
LOSTINMARS
  • 222 POSTS
sounds transmission related.
btw, you better get some more oil in the avalon, the v6 takes more than 4 quarts.
Feb 7, 2007 at 9:38 AM
