99 avalon timing isssues
1999 TOYOTA AVALON
JTREE64
I have a 99 avalon, toyota replaced a leaky waterpump and did a new timing belt around 58k miles. The car now has roughly 60 k and I have had an extreemly rough idle since a few weeks after the toyota service. Toyota said nothing was wrong when I asked about the idle so I took it to a conrads goodyear, where they found that among several loose and missing bolts on the tming cover they chiped the crank pulley and positioned the cams off by 2 teeth on the rear bank and 1 tooth off in front. Conrads corrected the problems and the car ran fine for a few days but now it runs just the same as it did before. The car was returned to goodyear to find that it is timed wrong again, they reset it and said they need to research it some more to figure out what is going on. Any ideas what could cause this? Could the improper timing have damaged the valvetrain?
Feb 7, 2006 at 3:36 PM
2CARPRO JACK
  • 11,533 POSTS
possibly. If it keeps skipping time then check the t-belt tensioner
Feb 10, 2006 at 2:06 PM
BUBBLES
  • 4 POSTS
Ever try bubble gum on the belt? LOL, just kidding. Like the other dude said if its a new belt and tight, then the pulley tensioner is the next thing check, bearings etc. The nice thing about fords tensioners is when they break they disengrate so you knowthat your bearing and tensioner are bad.
Bubbles
Feb 14, 2006 at 7:23 PM
