Gauges are not working
2003 TOYOTA AVALON
85,000 MILES • 6 CYL • FWD • AUTOMATIC
RONNYCUSA
I had to Jump Start my car and since then my car Guages will not operatre. ( Engine coolant temp. gauge, Tachometer, Speedometer, Fuel Gauge and the Multi Information Display.)
I tested all Fuses in the car and in the Relay & Fuse box near the Engaine. All the Fuses are good. (I don't know how to check the Relays.)
Please help me,
Ron
Jul 14, 2008 at 8:01 PM
There is a IG2 relay that needs to be checked here is the cluster wiring diagrams so you can see how the system works and a guide to test the relay with the relay location as well below.
Check out the diagrams (Below). Please let us know what happens.
Jul 16, 2008 at 11:00 AM
REY-GTS
Thank you for this post I had this problem and had to replace the cluster FYI
Feb 12, 2019 at 11:02 AM
ALBERTO VAZQUEZ
I had to Jump Start my car and since then my car gauges will not operate. ( Engine coolant temp. gauge, Tachometer, Speedometer, Fuel Gauge and the Motor oil pressure.)
Could you help me out with these problems?
I wait for your answer.
Thank You
Alberto
Feb 12, 2019 at 11:02 AM (Merged)
CARADIODOC
  • 34,306 POSTS
Check the fuses under the hood and inside the car. They often blow from the surge of a jump-start.
ALBERTO VAZQUEZ
I did it. N the problem stil there
KHLOW2008
  • 41,814 POSTS
These are all the fuses you need to check.
