Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Avalon
Interior
Instrument Cluster
Gauges
Engine Temperature
2002 Toyota Avalon temptpeture gauge is raises to high temp
2002 TOYOTA AVALON
102,000 MILES • 6 CYL • FWD • AUTOMATIC
ALTHEDON
MEMBER
1 POST
FOLLOW
what should i look for to try to correct this problem?
May 8, 2010 at 11:40 AM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
If the engine temp is normal and the gauge is reading high, replace the sender as it may be faulty.
mark (mhpautos)
May 9, 2010 at 3:45 AM
JSOHN
MEMBER
check the thermostat and do a pressure test to check for a coolant leak.
May 28, 2010 at 7:34 PM
