Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Avalon
Engine
Oxygen Sensor
Replace/Remove
2001 Toyota Avalon o2 sensor
2001 TOYOTA AVALON
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
TRUCKERDAVE
MEMBER
1 POST
FOLLOW
why wont the check engine light go out after i changed the oxygen sensor
Mar 28, 2009 at 5:34 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Need to have the code deleted. Either use diagnostic scanner to delete code or disconnect ground battery cable for 10 minutes then reconnect.
Thanks for using 2CarPros.com!
Mar 30, 2009 at 12:32 AM
WILLIAM OLIVER
MEMBER
disconect the efi fuse for 20 sec. wich is in the engine room side to the battery 15amp fuse ( blue color )
Mar 30, 2009 at 11:28 PM
