Okay, the fuel pump is in the fuel tank but you can get to it from the top.
I attached a diagram. You need to check for voltage on the blue wire to the pump when you turn the key on
Removal
Caution: do not smoke or work near an open flame when working on the fuel pump.
1. Remove rear seat cushion
2. Remove floor service hole cover
a. Take out the floor carpet.
b. Remove the 5 screws and service hole cover.
hint: at the time of installation, please refer to the following items. Check for fuel leakage.
3. Disconnect fuel pump & sender gauge connector
note: do not lift the fuel pump up with the wire harness picking.
4. Remove no.1 fuel tank protector
remove the 2 bolts and no.1 fuel tank protector.
torque: 4 nm (40 kg.cm, 35 in.lb)
Imageopen in new tabzoom/print
5. Disconnect fuel tube (fuel tube connector)
caution:
- perform disconnecting and connecting operations of the fuel tube connector (quick type) after observing the precautions.
- as there is retained pressure in the fuel pipe line, prevent it from splashing inside the vehicle compartment.
6. Remove fuel pump assembly from fuel tank
a. Remove the 6 bolts and fuel tank vent tube set plate.
Dec 28, 2020 at 12:11 PM
(Merged)
