1995 Toyota Avalon Engine blowing smoke
1995 TOYOTA AVALON
10,600 MILES • 6 CYL • FWD • AUTOMATIC
DSPITTLER
when I start my car after sitting for some time it blows out a ton of blue smoke,I also had to change all the spark plugs because they were fouled out.Can you refer a good repair manual for me so I can determine whether I should tackle such a task.This is a excellent running car execpt for all the smoke at start up,and using about 1 quart of oil per week.
May 31, 2008 at 6:09 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You can find a manual by clicking on the link at the bottom of your question. You problem will be faulty vale guides & valve guide seals. But i would do a leak down test as well to see what the condition Of the piston rings are like.
mark (mhpautos)
May 31, 2008 at 7:02 PM
