Over the last month, my 1.3L 2001 Toyota Yaris (UK)/ Echo (USA) automatic car has developed this howling/ whining noise when the car is in drive/reverse.
I have made a video of it.
https://www.youtube.com/watch?v=1hEx9yg9qpE&t=13s
I jacked up the car so the front wheels can spin freely in the air and the whine only happens when the wheel is spinning and goes away when i shift to neutral. While driving on the road the howling turns high pitch.
No whine in park or when in drive/reverse while wheels are stationary.
I have checked the gearbox fluid while it is hot and I can say it not running low. It is a bit brownish though.
Owner’s manual says the gearbox fluid doesn’t require changing, but I don’t buy this since I doubt the fluid can hold its properties even after eighteen years?
There are really really cheap used gearboxes units on eBay I could use to replace but before that I want to make sure if the other options I have listed below are worth considering first:
One of the options I am looking at is if a simple fluid change ( i.e. not just draining and refilling fluid by pulling the drain plug but I intent to dropping the pan and replacing the filter too) will fix the issue? I already bought the fluid, filter and the pan gasket but I don’t want to waste them if this method is not going to work. The fluid itself was a bit pricey
Considering I been driving with this issue for a month now, how much longer can I drive with this issue if I don’t take care of it?
Thirdly, say its the torque converter, what exactly is making the sound in the torque converter? Is it the sound of something loose or parts touching one another? Can it damage the entire transmission over time?
I read somewhere though that for it to be torque converter issue the whine has to happen ever when the car is both stationary and in gear. if the whine happens only when moving, then could be the bearing inside that's going bad?
Mar 31, 2019 at 2:35 PM
