couple questions. my rear wind shield wiper dosent work, i connected the wiring and hose for the fluid but when i flick the switch for it to turn on it dosent work. also when i take my truck 4x4ing everythign is runnign find engine temp gauge says its fine but when i park it it smokes.. and radiator is full.., and finaly the BIGGEST issue. i had to get my truck towed from harrison to langley becasue truck broke down, nothing electical or mechanical works on the truck know the fuses are fine. have no idea how to check the relays, when you put the key in the ignition and turn it no interior lights come on not even the dome light when you open the door or slick the switch. so im pretty sure its electrical but i have no idea what the problem it
toyota 4runner 1987 Sr5 with 22re engine
around 320(but has a recent rebuilt engine with only 5 thousand k on it)
manual transmission
2 wheel but can change over to four
no sounds or clicks
no leaks
no past repairs
manual transmission
no sounds or clicks
no leaks
no past repairs
Jun 11, 2007 at 2:01 AM
