Clutch Slipping
TOYOTA 4RUNNER
N2MONEY
1995 Toyota 4Runner 4x4, with 168k miles. The clutch will at times fade when being pressed down like in traffic. At times when sitting at a stop light the pedal will fade completely out and the vehicle will start moving or die. I can then put my foot under the pedal, move it forward then pump it and it starts working fine again. The problem is irregular and does not happed regularly but is becoming more regular. I cannot find any leaks in the lines and the fluid is full. What is going on and how can I fix it.
Aug 5, 2007 at 11:38 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
If you are sure that there are no leaks in the system, (peel back the rubber boot on the slave and have a good look there) The master cyl may be by passing fluid past the pressure seal. If the car wants to move off as the pedal is de pressed the pressure is forcing fluid back passed the seal and into the resivoir, so you will not notice any fluid loss.
Mark (mhpautos)
Aug 6, 2007 at 12:39 AM
