I have a 4wd Toyota 4Runner 05 w/ 50K miles. I recently changed the battery in my 4Runner and ever since then, when I start the engine, it does so just fine but directly after starting it goes to a very low idle and all almost all the dashboard lights stay on.
I can't put the vehicle in Drive or any other gear, nor can I open my rear hatch or windows. I did double check that the Battery is the correct one. 875 CCA. I did pop the fuse box and there were (4) fuses bown. (2) 20 amps (radio, (1) 30 amp (towing) and (1) 10 amp "ETCS" not sure what that means. I checked all the other fuses in the box under the hood and in the cab and these were the only ones blown. I'm not sure when they were blown but I do know everything was working just fine before I changed the battery (other than the battery dying on me ittermittenly). PLEASE HELP....
Dec 27, 2009 at 2:19 PM
