my Daughter just bought a 01 fourrunner that has some axle grease seeping from the axles, when you take the tires off you can see the differential oil has leaked from the seal. could you tell me if this is a easy fix or a difficult one, i havent ever done a seal or bearing replacement on a toyoya but i have on chevys several times, does the axles have a c cliip in the housing holding the axle or are their a retaining bolts behind the wheel on a axle flange. on a scale from 1 to 10 how difficult is this job for a old man to do.any advice would be truly appreciated as my daughter is on a tight budget and the dealer told her it would run around $700. which is out of her financial reach and she needs her vehicle for work. thanks Don
Jan 19, 2009 at 1:40 PM
