2001 4 Runner leaking water on the drivers floor board
2001 TOYOTA 4RUNNER
CHROME350Z
I have a 2001 Toyota 4 Runner with the 6 cylinder engine, 2wd WITH a sunroof. About a year ago I started to notice the floor board in front of the drivers seat was getting wet when it would rain. The carpet right next to the kick panel on the left side of the floor board is where it is getting wet (near the left side foot rest). Earlier this week it rained and my drivers floor board was complete soken wet, worse than it has ever been. I pulled the carpet up to see if I noticed anything. I punched a small hole in the 2 plastic plugs in hopes to help drain the water but I would like to know what I need to check in order to fix the problem.
Thank you in advance for your help,
Ryan
Sep 29, 2007 at 9:42 AM
BMRFIXIT
  • 19,053 POSTS
[quote:7d896533c3="chrome350z"]I have a 2001 Toyota 4 Runner with the 6 cylinder engine, 2wd WITH a sunroof. About a year ago I started to notice the floor board in front of the drivers seat was getting wet when it would rain. The carpet right next to the kick panel on the left side of the floor board is where it is getting wet (near the left side foot rest). Earlier this week it rained and my drivers floor board was complete soken wet, worse than it has ever been. I pulled the carpet up to see if I noticed anything. I punched a small hole in the 2 plastic plugs in hopes to help drain the water but I would like to know what I need to check in order to fix the problem.
Ryan[/quote:7d896533c3]
Sun roof seal is it ok ?!
If you open the sun roof and look in around the track for a small holes
They should be clean and free off dirt ,use compressed air to clean it
Good luck
Let us know
Sep 30, 2007 at 6:59 AM
BUZZSAW
  • 1,198 POSTS
[quote:3e1b2083cb="BMRFIXIT"][quote:3e1b2083cb="chrome350z"]I have a 2001 Toyota 4 Runner with the 6 cylinder engine, 2wd WITH a sunroof. About a year ago I started to notice the floor board in front of the drivers seat was getting wet when it would rain. The carpet right next to the kick panel on the left side of the floor board is where it is getting wet (near the left side foot rest). Earlier this week it rained and my drivers floor board was complete soken wet, worse than it has ever been. I pulled the carpet up to see if I noticed anything. I punched a small hole in the 2 plastic plugs in hopes to help drain the water but I would like to know what I need to check in order to fix the problem.
Ryan[/quote:3e1b2083cb]
Good luck
Let us know[/quote:3e1b2083cb]
their should be a hole in the lft front corner of sun roof open it up and look for debris, try pouring some water down it see if it leaks out the bottom of truck, tube may be off also
Oct 1, 2007 at 4:30 AM
