The antenna on my wifes toyota has been broke for a year.When you start the car you hear a grinding noise from the motor that extends the antenna.The antenna is in the extended position and works fine.I have tried getting to the base from the fender well from the engine compartment and through the door frame with no luck.Is this thing on a separate fuse that could be pulled?It is driving me insane.How can I disconnect the motor on this antenna?
Jun 17, 2008 at 10:38 AM
