2000 Toyota 4Runner Random Misfire Cyl 3
2000 TOYOTA 4RUNNER
171,000 MILES • 4 CYL • 2WD • AUTOMATIC
KARIURIAS
Codes read a random misfire with Cyl's 1, 3 and 4. Changed out all the spark plugs, ignition coils/packs, and downstream o2 sensor, yet the check engine light came back on once the battery was hooked up and the car was driven for a mile. Does check engine light need to be reset? Or does this mean there is still a problem?
Aug 20, 2010 at 11:42 AM
DOCFIXIT
  • 18,828 POSTS
Hi
What are codes ?P0301-P0303-P0304 or P0300
Was MAF cleaned?Fuel pressure verfied? Do you have a scan tool? if yes does it have engine miss and freeze frame functions?
Let me know
Thanks for donate
Aug 20, 2010 at 12:55 PM
MERLIN2021
  • 17,250 POSTS
It could have retained memory, try this method to reset the ECM(PCM).
RESET PROCEDURE 2 1. Disconnect the negative battery cable for 5 minutes. 2. Reconnect battery cable. 3. Start the engine and warm it up to normal operating temperatures before test-driving. 4. Perform a thorough test drive with several accelerations from a stop with "light throttle" application until proper transmission shifting is verified. Does it run rough?
Aug 20, 2010 at 12:56 PM
KARIURIAS
Thanks for the feedback
to answer your questions:
Yes codes read: P0301-P0303-P0304
And yes the idle is rough, but smoother now that the ignition packs were replaced.
Do not have a scan tool, disconnected the battery, let car idle for 5 minutes then took test drive, and light came back on.
Aug 20, 2010 at 2:12 PM
MERLIN2021
  • 17,250 POSTS
3 out of four misfiring isnt good, lets check the fuel pressure and the egr valve for stuck open condition.
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
Aug 20, 2010 at 2:31 PM
MERLIN2021
  • 17,250 POSTS
If you have a coil pack setup, did you possibly misroute the wires? Of coil on plug, probably couldn't.
Aug 20, 2010 at 2:33 PM
