I'm having problems refueling my gas tank to capacity
2000 TOYOTA 4RUNNER
DKRAZYDINGO
I'm having problems refueling my gas tank to capacity. Everytime I go to refuel, the gas pump would stop and l would still have the ability to pump an additional 2 - 3 gallons (with constant pulling of the trigger). I've used different gas stations and still no difference. But I did notice that in some gas stations, I can sqeeze the trigger lightly (1/8 to 1/2 inch) and would be able to fill the tank. My car is a 2000 4 Runner, 2 wheel drive, V6 and I forgot the engine size (sorry). Can anyone help?
Sep 14, 2007 at 6:22 PM
MHPAUTOS
  • 31,937 POSTS
The issue you're experiencing with refueling your 2000 Toyota 4Runner could be related to a problem with the evaporative emissions system or a clogged vent hose. Here are a couple of potential causes and solutions:
Please check out this guide as well
https://www.2carpros.com/articles/troubleshooting-incomplete-gas-tank-filling-causes-solutions
Evaporative Emissions System: The evaporative emissions system in your vehicle is designed to capture and store fuel vapor. If there is a problem with this system, such as a malfunctioning vapor canister or a faulty purge valve, it can create excess pressure in the fuel tank, causing the gas pump to shut off prematurely. A malfunctioning system may not allow proper venting during refueling.
Solution: Have the evaporative emissions system inspected by a qualified mechanic. They will be able to diagnose any issues and recommend the necessary repairs or component replacements.
Clogged Vent Hose: The vent hose in the fuel system allows air to escape as the tank is filled with fuel. If the vent hose becomes clogged or obstructed, it can prevent proper airflow during refueling, causing the pump to shut off prematurely.
Solution: Inspect the vent hose for any signs of damage, kinks, or blockages. Clear any obstructions or replace the hose if necessary. It may be helpful to consult a repair manual or seek professional assistance to locate and access the vent hose properly.
Additionally, here are a few general tips that might help with refueling:
Slow Down Fueling: Try refueling at a slower rate. Sometimes, pumping the fuel at a slower speed can prevent premature shut-off.
Adjust the Fuel Nozzle: While refueling, try adjusting the angle or depth of the fuel nozzle within the fuel inlet. Sometimes, finding the right position can prevent the pump from shutting off prematurely.
If the issue persists after attempting these suggestions, it is advisable to consult a qualified mechanic or take your vehicle to a Toyota dealership. They will have the expertise and specific knowledge of your vehicle to diagnose and resolve the refueling problem accurately.
Sep 15, 2007 at 7:06 AM
DKRAZYDINGO
It was the fuel fill tube was pinched off so I got a new one, all set. Thank you
Sep 15, 2007 at 6:53 PM
