1999 Toyota 4Runner Starting
1999 TOYOTA 4RUNNER
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
SEACOAST
I chnaged my plugs, wires, and airfilter at the recommended mileage. It is factory recommended parts.
The starting has changed.
Before ..... one turn and it would start hard and strong. Now it turns a few times and fire. The idle in both cases resume back to normal.
I have changed oxygen sensor on another ocassion. The analysis machine does not read a problem.
Oct 19, 2008 at 3:41 PM
Check the fuel pressure-if okay start with the coolant temperature sensor-this the one that tells the computer the engine is cold needs fuel before the oxygen sensor takes it over during closed loop mode-
Oct 19, 2008 at 5:15 PM
