[quote:97d66399f1="steelcity4runner"]Engine Performance problem
1994 Toyota 4Runner 6 cyl Four Wheel Drive Automatic 134000 miles
94, 4runner, has recently started having trouble keeping a steady idle, will start and and idle fine, but after heating up, it jumps and will stall. have tried adjusting the idle. at around 3000-3500 rpm's the engine will sound as if stuttering or possibly not receiving enough fuel. acts incredibly sluggish. also will use almost full five quarts of oil around two thousand miles, with no visible leak or drip. also has eradic high pitched whine when accelerating. any ideas on where to start looking?[/quote:97d66399f1]
I had this same problem with my '04 Xterra a while back and with my '94 4Runner just recently. Try checking your mass air-flow sensor, MAF. If it is dirty or blown your ECU won't get correct oil/air/gas readings which makes your car think that you are either getting too much of something, or not enough.
Jan 7, 2021 at 6:45 PM
(Merged)
