Ok so I went mudding about a week ago and hydrolocked my engine. I pulled the plugs and turned The engine over manually to get as much of the water out as I could and then did a tune up and oil change and changed the transmission fluid out. In addition to that I took everything off all the way down to the camshafts to clean it out. After I cleaned it out I put everything back and tried to crank it and nothing. I checked the compression it was at 120. I didn't know of that was normal or not because of the miles. And I pulled the plugs and made sure they are firing and they were good. And I am getting fuel because I can smell it on the plugs. Any ideas what might be wrong?
Oct 12, 2010 at 11:05 PM
