Just replaced timing belt, water pump, and new tensioner pulley. All timing marks line up on cam pulleys and crank pulley and crank gear. At tdc I get normal compression on number 1 cylinder. Motor starts relectantly when it will but soon stalls with a strong smell of gas in the exhaust. If you think it is the timing, how do you adjust, or is there something I'm missing. Thank you
Jan 26, 2010 at 9:58 AM
