1997 Toyota 4Runner Key Won't Turn
1997 TOYOTA 4RUNNER
127,000 MILES • 6 CYL • 4WD • AUTOMATIC
BENKNIGHTON
This morning the key locks on the doors were frozen and my wife slightly bent her key when trying to turn the lock. She had a little trouble getting the ignition switch to turn but was able to wiggle it on. Later that day I drove it around town with my own key with no problem. Finally, tonight she stuck the key in and it stuck half-way between on and off and now it will only move half-way to accessory power. My key will not do anything and I even tried to shimmy the steering wheel a little to get it to un-stick. Any ideas for a quick-fix, or will it be a new ignition switch... or more. Anything would help.
Jan 15, 2008 at 11:31 PM
FISHERMAN
  • 937 POSTS
[quote:561f30d9b9="benknighton"]Other Category problem
1997 Toyota 4Runner 6 cyl Four Wheel Drive Automatic 127000 miles
This morning the key locks on the doors were frozen and my wife slightly bent her key when trying to turn the lock. She had a little trouble getting the ignition switch to turn but was able to wiggle it on. Later that day I drove it around town with my own key with no problem. Finally, tonight she stuck the key in and it stuck half-way between on and off and now it will only move half-way to accessory power. My key will not do anything and I even tried to shimmy the steering wheel a little to get it to un-stick. Any ideas for a quick-fix, or will it be a new ignition switch... or more. Anything would help.[/quote:561f30d9b9]
Hello !!
Use some Graphite powder get a tube of it and pour it inside the lock then try to turn the key little by little one way to the other until the cylinder gets free..
that graphite powder its fantastic on locks!
good Luck and let us know if works for you!!
Jan 15, 2008 at 11:53 PM
BENKNIGHTON
I tried some graphite and nothing seems to have changed. What would be the procedure to take the ignition switch out and go from there?
Jan 16, 2008 at 2:46 PM
FISHERMAN
  • 937 POSTS
[quote:aa9b045570="benknighton"]I tried some graphite and nothing seems to have changed. What would be the procedure to take the ignition switch out and go from there?[/quote:aa9b045570]
If your 4runner its airbag equipped i do not recommend you to do it yourself because if by accident you apply power to any component the air bag may deploy, you have to deactivate the air bag system before, if you want a risk it, try to get the mitchell for your car because there`s a lot of steps involved..
godd Luck!
Jan 16, 2008 at 7:34 PM
