My 4 runner has had a little bit of a loose rear end. The rear passenger tire is worn down the middle of the tire, no other tires are worn.
I pulled both rear tires and hubs. Everything looked good on the rear passenger side (the one with the bad tire), but on the rear driver side there is fluid all over the place. The fluid smells like deferential fluid. The rear breaks work fine and the break cylendar is not leaking.
I am assuming the loosness and the wear on the rear passenger tire are coming from an issue with the rear driver side...somewhere.
Any suggestions are appreciated.
Jul 28, 2008 at 2:00 PM
