1997 Toyota 4Runner cclock removal
1997 TOYOTA 4RUNNER
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
FRANK FRENO
how to remove clock from dash
Sep 14, 2010 at 8:16 AM
DAVE H
  • 13,384 POSTS
Removal & Installation clock is mounted to right of instrument cluster in instrument cluster center finish panel. Remove A/C switch, heater control knob and heater control panel. Remove 2 center cluster finish panel retaining screws. See Fig. 4 .
https://www.2carpros.com/forum/automotive_pictures/266999_clo_1.jpg
Using flat-blade screwdriver, carefully pry panel loose from 7 retaining clips. Disconnect wiring harness connectors. Disconnect A/C control cable. After center cluster finish panel has been removed, remove clock from panel. To install, reverse removal procedure.
Sep 16, 2010 at 4:45 PM
